358 cam upgrade
Old Aug 12, 2024 | 07:43 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
358 cam upgrade
Soo, after years of running current combo, finally took on some damage. Current spec 358 cubic inch, 4 bolt block. Forged everything. Was running some gm fastburn heads with some port work. Zz409 cam. And a welded/ ported super ram. Used to snap up noce and kiss 6500, we'll used too.
im switching the heads over to some older brodix units, 2.05 /1/60 valves. ( yes piston clearance is all good) only question is does someone have a recommendation on upgrade to cam. Im Right at 10:1 compression. 1.6 rockers. Manual trans. 3.54 gear. Not super concerned with drivability as its just a toy. Just wondering if theres better options.
Thanks for any suggestions
Old Aug 13, 2024 | 05:44 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: 358 cam upgrade
Comp cams will figure out and grind you a custom for not too much over a stocked unit. I think I paid $280 for mine. Told them exactly what I had, what I was looking for, and what my use case was. They sent me their recommendations and I got it like a week later.
Artic-Trans am
Dec 10, 2014 11:22 AM
thatsupnow
Nov 2, 2014 11:52 AM
aceez71
Alternative Port EFI Intakes
46
Jun 4, 2010 11:09 PM
TPI-Formula350-
Feb 15, 2007 12:39 PM
cyclops2
Oct 30, 2003 05:22 PM
