Possible Misfire Condition New Cam
Old Sep 4, 2024 | 12:23 PM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
I swapped in summit cam #8800 and need some help diagnosing a rough idle. To me, it sounds like a potential misfire, but I have no idea where to start. The engine will idle smooth for a few seconds and then "hiccup". I don't want to run the engine too much in case it's a valve adjustment issue.
The car has the original E4ME carb with modifications based on Cliff Ruggles' book. Changes I've made: .036 idle tubes, .0465 down channel restrictions, mixture screw holes drilled out to .076, .082 idle bypass air.
Timing set to 10 degrees BTDC, mixture screws are 3.5 turns out.
I plan on pulling the plugs/checking the wire order, any other suggestions?
Old Sep 30, 2024 | 11:32 AM
Car: 86 Berlinetta
Re: Possible Misfire Condition New Cam
I solved the issue. My TDC mark was off, and as a result, the distributor was pointing at #2 at TDC...
Old Sep 30, 2024 | 02:38 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Did the outer ring on the harmonic balancer slip on the hub because the rubber bonding them went bad and that threw off your TDC mark or was it something else?
86ltrain
Jul 2, 2015 02:46 AM
CodyC123
Aug 28, 2009 05:58 PM
evoluzione1
Sep 22, 2005 07:58 PM
ehacker01
Mar 30, 2004 07:06 PM
Dragula
Carburetors
Sep 12, 2002 08:04 PM
