High pressure fuel hose on sending unit
Old Oct 28, 2024 | 10:03 PM
SteveC68's Avatar
Car: 1989 IROC
Engine: 5.7L
Is there a replacement part number for the short section of high pressure hose that has threaded connections on either end that is connected to the hard line from the sending unit? I bought a car that was sitting in a field for 25 years and have recently been going through the fuel system. All of those rubber short lines connected to the sending unit have seen better days.
Thanks,
Steve
Old Nov 1, 2024 | 11:45 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: High pressure fuel hose on sending unit
Thanks,
Steve
Pics help but on my sending unit there was no rubber lines it all hard line off the sending unit. Just buy a new sending unit they're cheap
Old Nov 15, 2024 | 07:41 PM
SteveC68's Avatar
Car: 1989 IROC
Engine: 5.7L
I bought a new sending unit. The hard lines run along the top of the tank and then turn down on the drivers side of the tank. There are 4 hoses (jump over lines) that connect each line. One is the fuel return, one is the vapor line, one is the over pressure line, and the last is the high pressure line. All except the high pressure line are connected with hose clamps. The high pressure line is a 16mm IFF fitting. At least on the sending unit side it is. The other end has a rubber hose with the correct fitting but it is permanently attached to the hard line that goes into the fuel filter. I just ended up buying a 12" long AN braided hose and the correct fittings and cutting/flaring the hard line that goes into the fuel filter.
Old Nov 15, 2024 | 08:33 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
A company call Fine Lines makes it. Part number FGL8204SS.
Summit carries also.
https://www.summitracing.com/parts/f...Bz7GU1g1GtI08R
Old Nov 15, 2024 | 09:38 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
They also make it in a steel version for a few bucks cheaper. For the small price difference I'd get the 304SS version.
Summit Racing - Fine Lines Fuel Lines FGL8204OM - Steel
Summit Racing - Fine Lines Fuel Lines FGL8204SS - 304 Stainless Steel
T.L.
Jul 1, 2022 12:49 PM
joshhsi
Nov 30, 2012 04:11 PM
ringo234
Apr 14, 2004 11:24 PM
m300slr
Mar 19, 2003 11:24 AM
