Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
There are lots of standalone systems out there. The Edelbrock pro flo xt will fit under the stock TA hood. Most of the 4 barrel looking EFI units won't. I used to have a pro flo that looked like a 4 barrel and it wasn't even close to fitting under the hood. It's a simple conversion. If you have a HO you'll have an in tank fuel pump that will complicate things. I don't think the LG4s for those pumps till 85 or so.
Thanks for the recs everyone, its an LG4 and not a HO motor and the entire fuel system is stock factory as of now so I assume there is no booster pump in the tank. A system that fits under the stock hood would be ideal.
