Fuel pump help
Old Feb 2, 2025 | 02:13 PM
old truck guy's Avatar
Fuel pump help
Looks like the authentic ep381 is pretty much history these days. What's everybody using now for higher flow/hp applications in a factory fuel system/tank? I've read reviews indicating the walbro's are noisy and tend to have a short life span.
Old Feb 2, 2025 | 05:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel pump help
What are you powering and what year is your rig. Nothing wrong with walbro pumps, however there are fake ones out there.
Old Feb 2, 2025 | 08:35 PM
Re: Fuel pump help
383 in an 84 k20 truck. Hoping for 400hp. Pretty much all gm vehicles with in the tank pumps/fuel injection in the 80's and 90's used the same style fuel pumps correct? Tbi, tpi, vortec etc. Wasn't the ep381 (vortec) the highest flowing one?
Old Feb 3, 2025 | 07:33 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Fuel pump help
That I don't know. I'm pretty sure the sending units changed when they went to fuel injection. Are you running a return line? Pressure regulator? Carb or fuel injection? All these factors matter for proper selection.
Old Feb 3, 2025 | 08:24 AM
Re: Fuel pump help
same kind of sending units and pumps gm used on I think all of their fuel injected vehicles from mid 80's to late 90's. Fuel supply, fuel return, tank vent and canister vent. Pressure regulators are up by the throttle bodies or fuel rails
Old Feb 3, 2025 | 01:40 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Fuel pump help
Right, but without knowing what's in your setup one cannot help. Are you running a carb? fuel injection (if so which one)? etc etc.
Old Feb 4, 2025 | 01:37 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Fuel pump help
Throw a Walbro 255 in there and be done with it
Boosted357
Dec 29, 2015 06:55 AM
williams160
Fabrication
May 21, 2010 03:18 PM
HI92Z28
Oct 16, 2002 07:31 AM
Markolc
Apr 16, 2002 06:49 PM
