Remove oil pan while transmission is out
Old Feb 16, 2025 | 10:55 AM
91vaneZ's Avatar
Car: 1991 Z28 convertible
Engine: 5.0L
Transmission: Auto 700R
Axle/Gears: Stock
Hello all
I tried searching but no luck. I have a stock 91 RS with a 305. I removed the transmission to replace the flywheel and some seals and noticed my oil pan is leaking.
Since the transmission is out, does the oil pan come out easily or do I still need to raise the engine? Doing some research ahead of time.
Just noticed the pan has some dents. Do you guys recommend a certain brand of oil pan as a replacement?
Thanks in advance.
Old Feb 16, 2025 | 11:34 AM
Beeman's Avatar
Re: Remove oil pan while transmission is out
Engine needs to be raise and with the transmission out it could get exciting, Be sure to remove the distributor cap if you lift the motor from it's mounts.
Old Feb 16, 2025 | 12:15 PM
gt4373's Avatar
Transmission: 5-Speed Manual
You Still Need To Raise The Engine
Fast92RS
Aug 9, 2015 05:38 PM
baboony
Dec 5, 2010 06:32 PM
SoSoFresh_SS
May 14, 2008 08:09 AM
Zokal
Nov 2, 2007 04:47 PM
