oil pan dent
Old Oct 31, 2009 | 07:07 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
oil pan dent
Ok so yesterday I was jacking my car up to fix a tranny leak and as I was jacking the car up the jack slipped. I bent my center link up into the oil pan. The center link is shot and I have a nice dent under the front of my oil pan. Has any tried one of those stud welders to pull dents out of an oil pan with out pulling the oil pan off. My oil pan is galvanized steel. I tried using the stud welder but just cant get the studs to stick good. I cleaned any oil off the pan and even sanded of the some of the coating. I dont now why it wont work. There is still oil in the pan, so I dont know if that causing a problem with the stud gun. If I dont get the dent out It looks like I will have to pull the pan off and that is going to be a huge PITA. Any suggestions.
Old Oct 31, 2009 | 09:38 AM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: oil pan dent
I would suggest taking the time to pull the pan and bang it out from the inside. The do it right or dont do it at all rule applies here. I wouldn't risk turning the oil pan into swiss cheese. Just my opinion though.
Old Oct 31, 2009 | 09:40 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: oil pan dent
You can use a stud welder if you grind off the galvanizing first. The only "right" way to fix that is a new pan. It's a PITA 3-4hr job, but worth it in the end. Even if you get the worst of the dents out, it's going to look crappy.
Old Nov 1, 2009 | 05:06 PM
Pocket's Avatar
Car: 91 Trans Am
Re: oil pan dent
I made the same mistake a few years ago. Solution is a new pan. Its not terrible, at $80ish brand new
Old Nov 1, 2009 | 06:59 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Re: oil pan dent
Yeah well I want to see if I can save the pan first. It was a $180 pan. Even if I have to take it off Im pretty sure it might be ok. If not then I will get a new one.
Old Jun 24, 2012 | 07:05 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Re: oil pan dent
Just an update I did eventualy replace the pan. I tried to take the dent out with a stud gun, but in the end I made a hole in the pan and tried to weld it but it leaked anyway. So I wanted to put a tubular K member in anyway so when I removed the stock k member I replaced the pan.
Old Aug 6, 2015 | 08:27 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Re: oil pan dent
old post i know... I just did the same thing today. Did you have to replace your center link? I'll be trying a stud gun tomorrow too.
Old Aug 7, 2015 | 09:40 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: oil pan dent
If you bent up the center link yes. And the op and no success with a stud gun so I'd probably be a lot quicker to just replace the pan
Old Aug 8, 2015 | 02:06 PM
Pocket's Avatar
Car: 91 Trans Am
Re: oil pan dent
If you bent it yes. If its 20+ y/o, yes
I had the unfortunate experience of one failing on the highway. Its a part that falls into the "when in doubt, replace" category
Old Aug 9, 2015 | 05:38 PM
TBRays98's Avatar
Car: 1989 Formula
Re: oil pan dent
Yea i bought a new center link but im still gonna try to use a stud gun on the oil pan. Mine is just the factory pan so hopefully it works out.
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
