1985 305 TPI smog delete
Old May 26, 2025 | 05:38 PM
rustyjones85's Avatar
in the middle of deleting my smog garbage. i removed the air diverter and now need to cap off the manifold check valves. but, what exactly needs to be removed? and how would i cap it off?
Re: 1985 305 TPI smog delete
Old May 26, 2025 | 05:39 PM
Old May 26, 2025 | 06:45 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
If you're able to get the check valves off..... (Threads tend to fail as you begin to wrench on them) I hear that the threads are 3/4" NPT. Simple cast iron black pipe caps I hear work.
To played it safe I left the check valves on and simply bought some rubber caps and used the stock clamps to hold them in place. Been running it that way for years and no issues.
Old May 26, 2025 | 06:56 PM
NoEmissions84TA's Avatar
Are you in a state that requires emissions testing?
Old May 26, 2025 | 07:45 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
This topic sure comes up a lot.
Why would you cap off the check valves rather than just remove them??...
Old May 26, 2025 | 08:35 PM
i am removing them, i just wanted to make sure i was on the right page. i’ve only seen smog deletes on later models and the check valves are different.
Old May 26, 2025 | 08:36 PM
no, which is why i’m deleting emissions stuff
Old May 26, 2025 | 08:37 PM
i have them soaking in pb blaster right now. i’ve also heard 1/2 inch caps work so i’ll just buy both and return whichever doesn’t fit.
Shaunejulian
Feb 24, 2025 11:00 AM
articwhiteZ
Jun 17, 2021 09:34 PM
Carystone92
Feb 23, 2016 07:33 AM
pgslunchbox
May 26, 2006 11:38 AM
CamaroEFI
Jun 9, 2003 03:08 PM
