For R134 Which Oil, How Much Oil and Which Orifice Tube?
Old Jul 3, 2025 | 01:37 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I'm getting ready to finally replace the compressor on my 1986 Camaro IROC Z. Car was converted to R134 in circa 2013. A shop did it. Compressor always has had a minor leak in it that has gotten worse and worse over the years. I have run dye through it myself and confirmed the leak. And before anyone says anything yes I am replacing the evaporator along with the compressor.
Reading through probably a good dozens old threads on this forum going back to circa 2007 or so. I've seen a ton of posts telling OP to replace the orifice tube with a red, orange or blue one from Ford. The most specific I've seen is someone suggesting to grab a 90s For Orifice Tube. Would any 90s Ford V8 work?
Also which oil should I use? I seen some posts suggesting Ester Oil others 100w PAG oil. How much oil total? I've seen some saying the system only needs 5oz others saying it needs 8oz. It might have three in the compressor. Should I add 2oz to the compressor and 3 to the evap?
Old Jul 3, 2025 | 02:24 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: For R134 Which Oil, How Much Oil and Which Orifice Tube?
Ford Red 0.062" is what I have had the best results with in most GM systems.
You should replace the accumulator as well. Flush the hard line and replace the hoses with new barrier style hoses. At that point you want Pag 150 for a R4 compressor. You want a parallel flow condenser with R134a and a dual fan assembly with a shroud that covers the whole radiator.
Old Jul 3, 2025 | 03:44 PM
Engine: LB9 305 TPI
Looks like the 90s F-150s have the Red 0.062 Orifice tubes. I'll order one.
cinder41
Sep 26, 2011 07:34 AM
IROC-ZeeUK
Jul 3, 2008 09:53 PM
1989karr
Aug 16, 2007 02:02 AM
gottfuel
Jul 15, 2006 11:05 AM
92blue
Aug 17, 2002 12:03 PM
