A few questions about heads....
Old Jan 24, 2002 | 07:27 PM
idrag2's Avatar
Ok guys heres the deal I have a 89 Formula with a LO3 it has around 50,000 miles and I just replace the valve seals about 6 months ago..........and now its doing the same thing as what it was befor---- when I let it idle under hi vaccume and then just tap the throttle it smokes blue smoke------but anyway I replace the valve seals and it quit but the question I have is how come the wore out so quick? And another question I have is we have a 305 out of a 91 Chevy P/K at work what is the differance between Pick up heads and Car heads if any???? This is my only car and I can't have it down for the time it takes to have the machine work done on the heads........can anyone help me out. Oh yeah what type of vlave seals should I use O'Ring, Umbrella, or positive type.......? You guys have always helped me out can ya help me out one more time?
Old Jan 24, 2002 | 08:05 PM
poncho9789's Avatar
What type of seals did you put on the heads were they viton,umbralla,stock o rings I understand the umbralla seals wear out quicker some one else might be able to be more specific on why the seals are going out. You could have valve guides going out causing the seals to wear out quicker. If I were going to replace the seals in my heads I would use the viton seals.
Old Jan 25, 2002 | 06:43 PM
idrag2's Avatar
Ok thats what I put on around here we call them positive type vavle seals "the ones that have the little bands around them" but why are they wearing out so quickly...........anyone else, and what about the truck heads?
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
