help please!!
Old Jul 20, 2025 | 03:14 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
help please!!
need some help please.
1990 iroc 305 tpi
bought it not running from sitting.
replaced
fuel tank
pump
sender
filter
injectors
temp sensor
i clean the fuel rail
but did not change FPR
car runs perfect on idle but under load as in driving it sputters and misfires
i started with plugs and it ran perfect for 2 miles and like someone flipped a switch it went back to the sputtering/misfire symptom
i then changed the
ignition module
coil
cap
voltage regulator
ran great for 2 miles and again went back to sputtering sympton
only thing that i can think of is the wires. the only part i have not replaced
idles perfect revs perfect in park
only when in drive and accelerating sputtering occurs.
#no codes#
maybe oil pressure switch?
how can it run perfect for a couple miles then all of sudden back to the sputtering.
any ideas?????
Old Jul 20, 2025 | 04:02 PM
sscooter's Avatar
Car: 86 trans am
Engine: 383 w true duals
Transmission: t56
Re: help please!!
did you check fuel pressure?? maybe you got a faulty pump
Old Jul 20, 2025 | 04:03 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
Re: help please!!
new pump ac delco
Old Jul 20, 2025 | 04:39 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: help please!!
Check fuel pressure, get a datalog.
Old Jul 20, 2025 | 06:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: help please!!
was the car fully warmed up before the drive or warmed up on the drive ?
Old Jul 20, 2025 | 06:37 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
Re: help please!!
car was warmed i drove it for a couple miles absolutely perfect night b4. i got on this am stated warmed for 2 min drove off 1/4 mile down like someone flipped a switch back to sputtering misfire no power.
Old Jul 20, 2025 | 06:50 PM
Engine: Lb9
Transmission: M20
Re: help please!!
It almost sounds like icm but since recently replaced I wonder about pu coil condition.
Old Jul 20, 2025 | 06:51 PM
Re: help please!!
Makes it sound like an open —> closed loop problem.
Most usual cause of those, is the coolant temp sensor. In open loop the ECM runs off of a pre-programmed program; in closed loop it starts looking at all the actual inputs it's getting from all the sensors. Main cue for it to do that, is coolant temp. Check that in your data log. Or, if you lack the wherewithal for that, just swap out the CTS. Less than $20, probably 15 minutes if you're slow like me, you can probably do it faster like most everybody else.
Old Jul 20, 2025 | 06:58 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
Re: help please!!
that was the first sensor i changed. would oil pressure sensor near filter do the same ? i read a post where it was.
Old Jul 22, 2025 | 11:21 AM
Engine: Lb9
Transmission: M20
Re: help please!!
The ops is backup for fp relay. So unless you’re pump isn’t running i wouldn’t replace it.
Old Jul 26, 2025 | 08:07 AM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
HELP PLEASE!
I've done some diagnostics. My fuel injectors test at 13.3 ohms warm, and fuel pressure is initially at 40psi to 30 but drops quickly there after. I've ruled out some potential causes and think it's an injector leak. When I installed the fuel gauge and removed the MAP sensor/brkt, the car ran smoothly hold fuel pressure 35-40 However, with the MAP sensor reinstalled, it ran rough. i went through this twice same result.
i remount the map at an angle it it runs great short of a slight rumble in acceleration most likely from the injector leak
any thoughts on maps and the mounting
should i test it or just replace
curious why car runs great with the map moved off the manifold to the side???
Old Jul 26, 2025 | 08:26 AM
Engine: Lb9
Transmission: M20
Re: help please!!
What injectors were used to replace the originals ? . As long as the map has a good vacuum connection it could be mounted any position and still work. Sounds like there is something wrong with it.
Old Jul 26, 2025 | 08:49 AM
Engine: Lb9
Transmission: M20
Re: help please!!
Misread your post, removing the map completely changes its reading. More than likely leaning out the air fuel ratio.
Old Jul 26, 2025 | 09:05 AM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
Re: help please!!
i didn’t remove and disconnect i unscrewed the brkt only for access to the fuel rail valve.
vacuum line and plug still connected just laided over to the side
Old Jul 26, 2025 | 11:12 AM
BURD's Avatar
Re: help please!!
Maybe have your mechanic look at it.
Old Jul 26, 2025 | 11:34 AM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
Re: help please!!
burd
idiot!
Old Jul 26, 2025 | 11:46 AM
Engine: Lb9
Transmission: M20
Re: help please!!
as you can see he’s asking for advice to fix himself
crazyman3737
Aug 17, 2020 02:10 PM
89Z
Aug 13, 2016 04:56 PM
ThreeOhFive
Jun 8, 2011 07:40 PM
firebd89
Oct 27, 2007 10:56 AM
Val
Oct 7, 2002 12:44 PM
