When pulling the engine....
Car: 1984 Z28
84 Camaro Z28, 305HO mated to a T5. Time to pull it and refresh it. Gonna stick with the 305 and T5, but gonna freshen both of them up. My question is should I separate the tranny from the engine or pull it as one unit? Most of what I have seen is to separate them, but just wanted to confirm with you guys. I looked around and did not see a thread on this, but it is late and I may have overlooked it.
Thanks!
Thanks!
Re: When pulling the engine....
Either way works. I've done it both ways. Which one is better depends on your tools & facilities. For most people it'll be easier to pull the engine out the top and the transmission from the bottom; and to put the transmission back in, including the bell housing, before the engine.
Car: 1984 Z28
Thank you both, I very much appreciate it! I'm going to ask my local mechanics as well as online reviews, but just in happenstance, does anyone have a trusted machine shop in central NC (I live closest to Chapel Hill)? Knowledge is power!
David
David
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
'Only way I've ever done it is all together, in and out. It probably is easier pulling them seperately...
Car: 90 Formula / T-tops
Transmission: MD8
if you pull out top, I'd venture a guess its easier to take hood off. But how hard is it to get hood back on and aligned?
Yes, the hood needs to come off.
Piece o cake. I have the lightweight "composite" L69 Camaro hood, and I can even do it by myself. Easier w another person but not a problem either way.
Paul2727
Mar 16, 2020 10:23 AM
Dokken10
Dec 29, 2007 05:21 PM
