build advise please
Old Nov 5, 2025 | 01:28 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
build advise please
need some engine build advise
current situation:
1990 iroc with a 305 TPI 700r4
The plan is to swap out the 305 w/auto for a 350 t56
what i have already:
-donor engine from a 91 corvette with a 350 and 113 aluminum heads all stock.
-TPIS big mouth intake
-large runners
-ported plenum
-new cam
possible 1.6 rocker if needed
“recommendations please”
since i need to burn a new chip for the 350 i might as well change the cam and do a little work.
my question is with the 113 heads that I already have I don’t mind spending up to $600- $800 to make them better if I was going to buy aftermarket heads that’s what i would spend,
would buying aftermarket heads be a waste since it’s a TPI‘s would worked 113’s be sufficient with the parts that I have?
Old Nov 8, 2025 | 08:21 PM
Newmanator's Avatar
Re: build advise please
current situation:
-large runners
-ported plenum
-new cam
Personally if I were already gonna be spending aftermarket price I’d just get new. If you ever decided to go a different route than the TPI you’d have decent heads already. But if you could work the 113’s for a decent price that’s nowhere near the price of new and wanted to stay within a budget that’d be something to consider too. Just my thoughts anyway.
Old Nov 9, 2025 | 12:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1.6 rockers are a poor mans cam swap. Since you're already going to swap the cam, get one with a grind that the rockers would have given.
Old Nov 9, 2025 | 01:38 PM
Cooper1's Avatar
Car: 90 iroc
Engine: 5.0
i did not realize that on the 1.6 rockers.
Old Nov 13, 2025 | 12:57 AM
PorterHale's Avatar
How is everything now?
Spoiler
Old Nov 13, 2025 | 09:15 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Deleted
Old Nov 13, 2025 | 09:17 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
I agree, no reason to rebuild those old heads, when you can get new for around the same price.
Benc1
Sep 12, 2013 07:13 AM
LB9Formula89
Oct 2, 2012 01:46 PM
86T/A_Ram_Air
May 24, 2012 08:05 PM
Matthew91-Z28
Nov 20, 2002 08:33 AM
hydra512
Nov 19, 2002 11:31 PM
