Is this the right crank?
Car: 1988 GTA
Howdy,
I finally got my engine parts back from the machine shop. Build will be near stock, 5.7 using the factory TPI intake, heads and ECU/PROM. Flat top 30 over hyper-u pistons, forged rods, mild cam (Comp K08-300-8), 1.5 roller tip rockers, 700r4 trans. My question is will the crank I bought work?
https://www.summitracing.com/parts/ESP-435334805700#overview
The machine shop thought I’d need a different crank or a different flex plate for this crank. Anyone know for sure, before I start measuring and assembling everything? Planning to use the factory flex plate or possibly a Rock Auto replacement.
Also, is anyone interested in me posting the build as I go along or is a stockish 5.7 build ‘meh’?
TIA,
Mark
TIA,
Mark
Transmission: T-5, TH350, T-5
Re: Is this the right crank?
If the 350 block you have is post 1985, you need a 1pc rear main seal type for sure. You certainly don't need a 900 dollar forged one for a stock build though. Was your old crank scrap? Why a new one? And the machine shop would typically know what you actually need. If you have a post 1985, stockish build this will be more in line https://www.summitracing.com/parts/esp-103523480
the flexplate you will need will also be any post 85 sbc.
Car: 1988 GTA
The question is if the listed crank will work in an ‘88 roller block with a stock (style) flex plate?
thanks,
Mark
It will work, absolutely. It's just $600 wasted on a stockish rebuild. I'd also reuse the crank if it isn't insurmountably damaged.
