White wire pass kick
Old Jan 19, 2026 | 06:39 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
I got a loose white wire underneath the passenger kick panel anybody give me a hand in finding it's home?
Old Jan 25, 2026 | 07:34 PM
Vader's Avatar
Re: White wire pass kick
White is used for:
Tachometer signal to the instrument panel;
EST feedback to the ECM, connector C1, terminal C8;
Vacuum regulator solenoid power from to the ECM, connector C2 terminal D8 (V-6 applications);
Courtesy light (interior) ground wire from light switch and dimmer module;
LH outside power mirrror;
AC compressor clutch, suppressor diode;
Power antenna "down" signal (and the relay is in that area);
Rear wiper motor power;
Rear cargo well light;
Fuel pump power, from relay to C200, where it transitions to tan;
Those are the common ones for 1988.
Old Jan 26, 2026 | 12:40 AM
Engine: 5.7 l98
Thanks, I realized when I opened my pass door the interior dome light wasn't coming on. I think that must be wire.
Old Jan 26, 2026 | 12:20 PM
Yup; most likely is supposed to connect to the light switch near the door hinges. Should have a quick-connect (slide) terminal on it, if so.
Old Jan 26, 2026 | 12:53 PM
Engine: 5.7 l98
Thank great help
danijohansen87
Jan 10, 2022 12:07 AM
danijohansen87
Oct 20, 2021 12:46 PM
airjordan6906
Car Audio
May 24, 2007 05:10 PM
IceManRS305
Mar 22, 2007 07:45 PM
Project: 85 2.8 bird
May 8, 2004 08:58 PM
