Prime motor in forward or reverse with drill?
Old Jan 25, 2002 | 12:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I tried fora few secs and it seems to work better in reverse is this the right way? when tried in forward i had a hard time keeping the primer in the pump
Old Jan 25, 2002 | 01:08 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If I remember right, it'll be reverse on the drill.
You'll know when it primes. It should load the drill down a bit. So which ever way it loads the drill down is the right way.
Old Jan 25, 2002 | 01:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
clockwise looking down on the dist
You will hear it bubbling if you got it wrong.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Cameeeero
Aug 20, 2015 03:06 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
