thermostat install question
Old Jan 26, 2002 | 06:04 PM
JeffC1500TBI's Avatar
ok my new chrome thermostat has a rubber o ring around the inside.. does that mean I just bolt it like that without gasket?
Old Jan 26, 2002 | 07:07 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, but be on the lookout for leaks, the O ring style works if the thermostat mounting on the intake is perfectly flat and has no corrosion markings. (pitting, etc.)
I personally dont use chrome water necks ever, but when I install them on customer cars, I use a thin layer of RTV on the O ring.
Old Jan 26, 2002 | 09:36 PM
ok so I should just torque it down without the gasket then.. now the intake was all cleaned and cleared when the engine was rebuilt but it's an edelbrock performer intake.. the area around the thermostat is like a polished finish.. it should seal ok ?
is this something that could be ok and then start leaking later on?
Old Jan 26, 2002 | 09:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes, no gasket, just the O-ring.
As long as the intake surface is clean, you should be alright.
Good idea to keep an eye out for a future leak, Chrome t stat housings are notorious for leaks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
