angle or straight plugs heads?
Car: 1983 Z28
Engine: 6.6L 406
Which are you guys running? Do angle heads make it easier to change plugs? If you had a choice which would you get?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
make sure the headers will fit angle
some plug angles used are different. check with afr and make sure they will clear the headers you hav.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can make more power with angle plug heads because the plug tip is pointed more towards the incoming air charge. The downside is that many headers don't offer enough clearance for the angle plugs. Using straight plug heads is an easier choice with little to no clearance problems.
evilstuie
Feb 28, 2016 03:33 PM
