After installing a starter, I have a vibration now?
Old Jan 28, 2002 | 07:24 PM
BrianB's Avatar
I just got done installing my start today, and now with the car sitting at an idle in drive, the car has a noticeable vibration that wasn't there before installation of the starter.
NOTE : I did have to drop the Y-Pipe down and reinstall it to get the starter out and back in. I am also hearing a knocking sound every once in a while. Is there a possibility the exhaust is rattling against something under the car and causing the vibration as well?
Old Jan 28, 2002 | 07:29 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Quite possibly... Dumb question, but are teh fittings on the y-pipe tight? My brother replaced his starter and that was what was causing the rattling
Old Jan 28, 2002 | 08:23 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i'd look to the exhuast before anything else. I had this exact same problem not long ago and it turned out to be my drivers side header flange touching the frame and vibrating like crazy. Just loosen everything up a little bit and adjust it so it's not touching anything...
Eric
Old Jan 28, 2002 | 09:35 PM
BrianB's Avatar
I am going to climb back under there sometime tomorrow and take a look. I hope that is what it is. The y-pipe is nice and tight up against the headers. I just don't see how that could cause such a vibration, but I assume it is possible. It only really vibrates when the car is in drive at idle, and goes away when accelerating, but then starts the clicking type noise periodically.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
