mechanical fuel pump questions
Old Jan 28, 2002 | 08:38 PM
zach92rs's Avatar
Car: '92 RS
Engine: 350+
Transmission: 700r4+
i just got the holley 110 gph mechanical fuel pump(pn#hly-12-327-11) for my 92 rs (not rs anymore).
first, for those who have switched from electric to mechanical pumps, were did you get the plate which enables you to bolt the pump to the block. is this a part that can be bought at a parts store or is it a junkyard adventure.
second, how did you get the pump to fit when the motor mount is in the way? i ve heard about a bottom feed kit. can anyone give me a part number or point me in the right direction?
any help is more than welcome and thank you for your time. zach.
Old Jan 28, 2002 | 09:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can buy the plate new, or you can try to find it in a junkyard. Don't forget the gaskets and the pump rod too. You can remove the bottom of the pump and rotate it so that the inlet and outlet aren't obstructed.
Old Jan 29, 2002 | 07:41 AM
zach92rs's Avatar
Car: '92 RS
Engine: 350+
is the part available at a general auto parts store or will it only be found at the dealer? sorry for the stupid questions but i m short on time. thanks. zach.
Old Jan 29, 2002 | 08:07 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Something like that you'll probably only find at the dealer.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
