Cooling Fan problem.. tried everything..
I have a 92 RS TBI V8, and my cooling fan won't kick on anymore. I know it still works, cause I I just turn the AC on, and the fan comes on. So I know it works but it won't come on when the engine gets hot. I have checked the fuse, replaced the relay, replaced the cooling sensor that screwes into the block.. I don't know what else to do except wire a manual switch... any ideas??
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check the wire between the fan relay and the fan switch that plugs into the head. Sounds like a bad wire.
