460778 anyone know anything about this engine
Old Jan 31, 2002 | 07:43 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
460777
460778
i looked up my engine 460778 but cant find any other specs on it ..i know its a 305 and it has 14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers heads.......anyone know anything else about this motor...my buddy told me it had deep dish pistons...and the spark plugs do protrude into the combustion chamber more that the plugs on my monte do.....hmmmm...LOW COMPRESSION????
78 305
NON CC q-jet
th350
performer intake
edelbrock open element
edelbrock TES 3"
3"catco cat
3.73 gears
digital tach
rear spring rubbers
any idea on horse for this thing...?? i'm restoring it ..never drove it. ................................should be fun..
thanx guys .....
MAN this is an addicting board....
Rob
Old Jan 31, 2002 | 09:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
460778 - 1978-79 305. 2 bolt mains. Found in cars and trucks.
460777 - 1976-1979 305. 2 bolt mains. Found in cars.
Casting numbers don't mean much. The same casting can be used over a number of years and in many different types and models of vehicles. A 305 in a 1976 truck won't have the same specs as a 305 in a 1979 Camaro.
Old Feb 1, 2002 | 08:19 AM
Car: 1983 Z28 Clone
Transmission: TH350
that makes sense...........thanks
ahh i need a 350 ...i've seen the motor that i have
rated at 155 horse and 140 horse..but...again i dont really know that .............i'm pretty sure the compression is 8:1:1
thanx
Old Feb 1, 2002 | 08:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If you don't mind the 2-piece rear main seal, look for an 010 block. (last 3 digits in the casting number). These are the most popular 4" bore blocks. They were used in 327's and a lot of 350's. They can be 2 or 4 bolt mains. The 010 block is a stronger, high nickle block.
I've broken a few of them. If I was building another SBC, that's the casting I go looking for. They're easy to find in pickups.
Once you have a block, the HP rating all depends on the parts you put into it. Just because an engine is rated at 140 HP doesn't mean that's what you have to live with. A simple cam and intake swap increases HP and torque.
Old Feb 1, 2002 | 08:42 PM
Car: 1983 Z28 Clone
Transmission: TH350
i've never done a cam before.....gotta wait till next summer...
but i do have a quadrajet and a performer intake.....
sooo...........really all i'm concerned about is having more of a "pull" than my 84 monte does with a 305.......
i dont car about top end too much....i like that down low.....
rob
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
