engine code....please help
Old Feb 3, 2002 | 04:46 PM
Nasty_Bird_'90's Avatar
hey guys. i just read a code 12 from my aldl port and my car wont start. is the code 12 the reason why, or is it just a coincidence?
Old Feb 3, 2002 | 05:49 PM
1986redbird's Avatar
a code 12 indicates the computer is active (normal), can you explain a little more about the symptoms ??
Old Feb 3, 2002 | 06:01 PM
i turn the key. nothing. no solenoid click, nada. i know the starter and solenoid are good. i took it out and tested it. i ran a wire from the positive terminal on the battery to the starter where the wire from the ignition switch connects. when i tap this wire to the battery terminal (+), the engine turns over. as soon as it does, i remove the wire from the batt., and the engine will run for a second, and then dies. i thought maybe there could be a bad sensor, but you say the code 12 means the ECU is fine, correct? it cant be the ignition switch because when i turn the key, all the gauges read, as well as the radio and such. could it be either the VATS or PASS key systems, coil, distrubutor???? this one has truly got me perplexed.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
