Timing cover clearance
Old Feb 4, 2002 | 02:42 PM
91 RS's Avatar
I have just installed a edelbrock true rolling timing chain
(pn-7801) on my 89 305. The problem is that when i install my timing cover (aluminum) it is really close to touching the chain and with the timing cover gasket off it actualy touches. I was wondering how much clearance is required and if there is a problem how can i fix it.
Old Feb 4, 2002 | 03:11 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
most aftermarket t-covers are designed to be ground for camshaft adjustment of enply
there should be a piece of the cover that sticks out a bit right in the center of the top gear.. if you use a cam bushing (which your 305 probably does not), it would be ground down to make the endplay clearance correct.
If you have ok clearance with the gasket in place your alright.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
