Bigger Injectors?
Old Feb 6, 2002 | 05:56 PM
JR4444's Avatar
Bigger Injectors?
I heard that 24# Ford Injectors use different flow charts (or something) Then say Accel 24# ones. So do Ford and GM injectors flow the same, # for #.
Old Feb 7, 2002 | 04:12 PM
rezinn's Avatar
They flow the same, just ford injectors are rated at a lower PSI. That means that putting a ford injector in your gm car rated at the same 24#s will give you more fuel unless the fuel pressure is lowered.
Old Feb 8, 2002 | 06:05 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
THERE ARE FORMULAS ON THE MSD WEB PAGE. A FORD 24# IS RATED AT 37PSI AND UPPING TO THE GM PRESSURE OF 42+ GETS YOU 28#. THERE ARE ALSO FORMULAS TO CALCULATE THE SIZE OF INJECTOR YOU NEED FOR YOUR ENGINE (I AM SURE YOU MUST KNOW THE HORSE POWER). I AM USING THE FORD 24# ON MY 406 AT THE STOCK GM PRESSURE AND EVERYTING IS WELL. I DO RUN A LITTLE RICH, BUT I HAVE NOT CHANGED THE COMPUTER CHIP YET.
Fronzizzle
Feb 9, 2017 09:31 AM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
87hellbird
Sep 14, 2015 05:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
