17" vs. 16" wheel diameter
Old Feb 7, 2002 | 10:39 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
So, the 17's use 275/40's while the 16's use 245/50's. Do they have the same overall diameter (i believe its 26")? Am i correct in thinking the 17's just have 1" less sidewall? If they don't, what size tires would i need to have the same dia. i did with the 16" rims?
I never could get a grasp on this tire sizing stuff.
Old Feb 7, 2002 | 11:21 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Quick Lesson....
The P-Metric tire designation system....
P255/50-16 breaks down to-----
P- designates passenger car tire.
255- section width, in millimeters. this is measured at the widest part of the tire.
50-aspect ratio. the sidewall (in this case) is 50% of section width.
16-rim size.
To determine nominal tire diameter (unloaded) the formula goes like this
((section width * aspect ratio) * 2) /25.4 + rim size = nominal diameter.
Hope this helps.
Old Feb 7, 2002 | 11:28 AM
Sparkee's Avatar
Contact TireRack and check with them about tire sizes. I have changed tire sizes and always verify the sizes with them to make sure the speedometer is accurate. They have been right every time. Those plus/minus things people use to change tire sizes are not always accurate. They are pretty close but not always exact.
The 275/40's may not fit your car without rubbing. It depends on the offset of the rims you use. I just put a set of 275/40VR17's on a co-workers Trans Am, and let me tell you, those are some big tires!! He has a 97 Ram Air TA and it came stock with those tires, so everything fit. Have a good one.
Matt
Old Feb 7, 2002 | 11:40 AM
cfabe's Avatar
http://www.miata.net/garage/tirecalc.html
Check this out, it'll let you compare 2 different sizes and give you all the relevant mesurements.
Old Feb 7, 2002 | 05:04 PM
Sparkee's Avatar
That's a cool link. I'll just have to bookmark it for future reference. Later.
Fronzizzle
Feb 9, 2017 09:31 AM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
