Lower radiator hose?
Old Feb 9, 2002 | 02:32 PM
Brett Gutshall's Avatar
Ok so I open up the garage door this morning cause I figure it's nice so I'll take the Formula to work and what do I see? A big puddle of anti-freeze running out right under the drivers side door. I check the coolant level...nothing. Anyone know what this could be? My dad says lower radiator hose. I looked underneith and you can see antifreeze right on the front of the oil pan and some hoses around that but my dad said it probably just sprayed onto them. What do you guys think?
Old Feb 9, 2002 | 02:50 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Could be :
Lower hose
Water pump leaking, running down lower hose
Thermostat housing gasket leaking, running down front of block
Front water passage on intake manifold leaking (real common) ,running down front of motor.
Since my cyrstal ball is broken, I can't tell you for sure which it is.
Looks like it time to get under there and check it out.
Old Feb 9, 2002 | 03:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Happened to me once, the lower hose clamp came loose, and started to leak.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
