what size heads
Old Feb 10, 2002 | 02:10 PM
jimmy's Avatar
what size heads
Hey guys, i was wondering what would be good size heads to run on a 305. Im almost done with my rebuild, and want to start saving up for new heads. My engine will be runnin flat top pistons, a bigger cam, its been bored .030 over. What kind of head would work good with these mods thatnks.
Old Feb 10, 2002 | 05:03 PM
sleeper's Avatar
well... if you can afford it go for aluminum
if you're on a budget you could get a set of iron 305 HO heads. They have larger valves than a stock head and flow better. A rebuilt set with bigger springs cost me $300 from a local dude. I ran them on a 350 and they made gobs of low end torque but farted out after 4800rpm. They'd go higher in a 305.
The largest valve you can use in a 305 is 1.94/1.50 otherwise you get shrouding.
Old Feb 10, 2002 | 05:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Get some 305 Vortec heads. They are good if your running a 305.
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
