flexplates
Old Feb 11, 2002 | 08:24 AM
GRENDLE's Avatar
flexplates
are 86 and newer the same as the pre 86 flexplates (stock 305-350)? i've seen different and same pn#'s from different manufacturers.
TIA
Old Feb 11, 2002 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. The bolt pattern is different where they bolt to the crank.
Old Feb 11, 2002 | 10:36 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
they are balanced differently also.
Old Feb 11, 2002 | 10:38 AM
GRENDLE's Avatar
ok that explains it. i wasnt sure if it was because of the rear main or not. so then the pn#' s that will fit both are probably dual patteren drilled. thanks i'm used to dealing with the pre 86 stuff.
Old Feb 11, 2002 | 10:40 AM
GRENDLE's Avatar
305-350's are internally balanced, did they start doing something different in 86?
Old Feb 11, 2002 | 11:33 AM
sleeper's Avatar
the newer style flywheels have a "bat" shaped weight on them and are not compatable with earlier cranks.
The number of teeth can be different too.
Old Feb 11, 2002 | 08:02 PM
zippy's Avatar
Engine: 5.3L
with the exception of 400's, 262 through 350 were internally balanced engines up until 1986. in 1986 when the one piece rear main seal was installed, the flexplate/flywheel end became external balanced and the harmonic balancer stayed internally balanced.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
