Compression ratio ?
Old Feb 14, 2002 | 05:30 AM
The Dirty Bird!'s Avatar
Car: 89 GTA
Compression ratio ?
If I add the following:
Headers (Dunno what kind to get)
Siamese Intake Runners
58mm Throttle Body
Dual cold air intake
With the increased air flow, will my chip modify the compression ratio to allocate for the change in increased air flow?
Old Feb 14, 2002 | 08:07 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Compression ratio is purely mechanical, and is determinded by the chamber volume, and the piston. (higher dome equals higher compression.)
That said, with your mods, assuming you have a MAF car, the computer can compensate for the changes, but, doing some prom burning would optimize the system for your engine, and give you more power.
Old Feb 14, 2002 | 11:15 AM
rezinn's Avatar
daaaaaaang.. where did you get a generater for your car? I thought production of those went out in the 70s. Shows how much I know.
Old Feb 14, 2002 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For sure. More like the early 60's...
Old Feb 14, 2002 | 11:43 PM
Dan91Z's Avatar
i just installed a generator.....
it's on a 1949 ford 8N tractor though :-)
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
