Who's built a 406?
Old Feb 18, 2002 | 11:24 AM
I FLY UH-1's Avatar
Who's built a 406?
Exactly that, I'm going to build one and was wondering about any problems with harmonic balancers and serpentine accessory belt drive and if there was any problems with balancing the motor for our application.
Not worried about intake, cam, or head selection, but what were any problems on the bottom end.
Old Feb 18, 2002 | 11:33 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
connecting rod bolt to cam lobe clearance
if you use anything other than a stock rod or something that has been stroker clearanced.
Either internally balanance it or use a externally balanced flywheel and harmonic balancer. Its that simple.
Old Feb 18, 2002 | 06:51 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The older heads dont have all the holes for the serpentine brackets. If you use a modern head the holes should all be there. The block already has the two bolt holes on each side for the brackets.
The larger balancer made slight contact with the oil cooler water lines. I just bent them a little for clearance.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
6998poncho
Sep 25, 2015 02:56 PM
