Roller Rocker Install
Hel all
I am debating installing a set of Roller Rockers onto my 89 Bird.
What do I have to do?
I can install regular rockers with no problem, but have -0- experience with rollers.
Peace
Joshua
Peace
Joshua
same thing if you can do one you can do the other. if the have a set screw on top of the rocker nut after you get the valve lash you want tighten the set screw then tighten the nut a 1/4 turn or so more.
Transmission: 4L80E/4L80E
Beware of fat aluminum roller rockers and factory baffled valve covers.
They don't like each other much. Usually, something's gotta give.
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
