More ignition problems....
Old Feb 18, 2002 | 10:22 PM
Val's Avatar
Val
Ok, my car has been having a problem with cutting out for a second then starting back up. It went on for about a two weeks and everytime I checked the ignition system with DVM everything checks out.
Well now it runs but when it warms up it dies and just gets worse as it warms up.
When I took off the module to check it, I decided to look at the pickup coil and, everything was shot. I had to get a new distributor.
So I have new::: plug wires, distributor, pickup coil, module.
I'm leaning toward the ignition coil, or possiblely a loose ground.
If anyone has ANY other ideas I'd like to hear them before I start again tommrow afternoon.
Old Feb 18, 2002 | 10:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'd buy another coil too. Try your system first. it no go put the coil on. If no go again return the coil back to autozone or whereever. Also check the 3 gounds on the back of the pass side head and the 2 or 3 grounds on the back of the driver side head
Old Feb 19, 2002 | 09:35 AM
Stroked-Z's Avatar
You might have a wire short somewhere and it's grounding.
Cant offer much advice here except HAVE LOTS OF PATIENCE!!
Good Luck.
Old Feb 19, 2002 | 09:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Check or have the fuel pressure checked. Could be clogged filter, low pressure, etc.
Old Feb 19, 2002 | 10:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Does it only cut out in OD. Maybe check to make sure the TC lockup is working properly.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
