What were Dremel Porting Bits?
Old Feb 19, 2002 | 04:18 PM
GreenProStreet's Avatar
Some one along the line mentioed some bits that could be used for porting heads with a Dremel. They were a smaller diameter shaft than the die grinder bits. Anyone know?
Anyone ported with a dremel? Thoughts?
Old Feb 19, 2002 | 06:15 PM
ede's Avatar
ede
i'd buy or barrow a die grinder and some carbide bits before i tried with a demeral
Old Feb 19, 2002 | 06:19 PM
camaro6spd's Avatar
the dremel would be good for little stuff. I plan on using a die grinder but then again I have access to an air compressor.
Old Feb 21, 2002 | 06:10 PM
Niether do I.
Just, bumping it up in hopes someone knows a cartrige cutter for the Dremel.
Pleez!!!:hail:
Old Feb 21, 2002 | 09:14 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: What were Dremel Porting Bits?
I used a carbide bur in my dremel with the cable. I ported both heads, intake, runners, and plenum with 1 bit. I got it at a farm store near me for less than 20.00. Dremels are just as fast as the die grinders , and a LOT less noise. Check some industrial supply hardware stores for the carbide bits they work much better than stones.
Fronzizzle
Feb 9, 2017 09:31 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
Nick McCardle
Sep 10, 2015 08:36 PM
