Code's 32,33 And 36 Newbe Need Help Please!!
Old Feb 19, 2002 | 08:03 PM
CEDOE's Avatar
HI, I JUST BOUGHT MY FIRST THIRD GEN ITS AN 89 FORMULA WITH THE 305 FI , BEEN HAVING A FEW PROBLEMS SINCE I GOT IT.
1) IT IS STARTING TO HESITATE "WHEN I GET ON THE GAS"
BUT RUNS STRONG AFTER A SEC OR TWO
2) I NOTICED TODAY THAT IT WASN'T OR DIDNT SEEM TO BE SHIFTING PROPERLY ALMOST LIKE A CLUTCH SLIPPING
BUT ONLY EVERY NOW AND AGAIN NOT ALL THE TIME.
THE GUY I BOUGHT IT FROM JUST GHANGED THE MAS AND T TRIED TAPPING IT AND CAR IDLES FINE AT IDLE.
IM GETTING CODES 32,33 AND 36 ANY HELP WOULD BE GREATLY APPRECIATED!!!
THE CATS ARE HOLLOW AND DRIVETRAIN HAS 124,000 MI ON IT
EDELBROCK CAT BACK ALL STOCK OTHERWISE.
Old Feb 19, 2002 | 09:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
First thing is the release the caps lock key.
32 is EGR, 33 and 36 are MAF (assuming you have a TPI engine?) Would suggest trying new MAF relays and searching the boards for code 32.
Old Feb 19, 2002 | 09:35 PM
CEDOE's Avatar
thanks mike and sorry about the caps.
will try and see what happens
thanks!
Old Feb 20, 2002 | 09:08 AM
Vader's Avatar
CEDOE,
Repairing the '36' may solve the '33' as well. A DTC 36 is for a MAF burnoff cycle failure. This means teh MAF hot wire did not complete a burnoff cycle on the last engine shut down. Repeated failures of the MAF burn off can result in accumulations of dust and residue to build up on the MAF sensor hot wire, causing incorrect MAF readings and poor fuel control. Check teh MAF burnoff relay and electrical connector at the MAF sensor itself.
The '32' indicates an EGR system problem, and coupled with your other error codes, I would suggest checking the throttle position sensor voltage adjustment. An incorrect TPS setting can skew the MAF readings and prevent the ECM from enabling the EGR.
Old Feb 20, 2002 | 09:18 PM
CEDOE's Avatar
thankx mike and vader!!!!
i changed both MAS relays today and also found a wire that looked to be hanging out of another relay plug that was next to the ones i changed . so i fixed that also.
I've put about 50 miles on the car today with no ses warnings yet.
hope that was all it was .$18 for 2 relays and about 15 min to change them.
i would have been lost without you guys thanks again!!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
