what water pump pulley do i need?
Old Feb 20, 2002 | 07:58 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
My IROC came with accesories but no engine, the alternator has a serpentine pulley but the steering pump has v belt so I'm gettin the crank pulley w/serp. and two v belt slots for the mixed belt setup. so what water pump pulley do i need? what engines had this pulley and also what engine had the serp/v crank pulley?
Old Feb 21, 2002 | 08:01 PM
Car: '87 Camaro LT
Engine: 355 L98
I know someone knows this...
Old Feb 21, 2002 | 08:51 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
you need a "serpentine"/v-belt water pump pulley combo. i believe only 86' SBC's came with the serpentine/v-belt combo. you can get one from a camaro, firebird, caprice, etc.. in 85'only v-belt, and in 87' true serpentine setup. good luck
Old Feb 22, 2002 | 12:39 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
1985 had the same setup-tsb #85-126 belt failure-it lists the pulleys that you need but it requires #'s from the old ones-which aint happenin here-talk nice to the parts guy and he will tell you which of the 2 listed you need. i think the difference is whether its a v6 or v8. both c-shaft #'s are 14088682 or 14088683. water pump drive pulleys= 14088684 or 14088685. common alternator pulley #14095231 and 5 rib belt#14088983 affecting vin codes z, h, g. vin z = 4.3 later
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
