Oil pan on a 400 in a thirdgen
Old Feb 20, 2002 | 10:30 PM
Blackened's Avatar
Would it be okay to use any driver's side dipstick, two piece seal, 350 oil pan on a 400 block ? Or do I need some sort of special pan to clear the thirdgen's crossmember ? Thanx
Old Feb 21, 2002 | 01:46 AM
Stroked-Z's Avatar
Should be the same pan & should have no probs fitting.
Old Feb 21, 2002 | 02:36 PM
SoCo80p's Avatar
the 350 and smaller blocks use a shorter width wise oil pan, the 400 uses a wider pan to clear the longer stroke of the 400. you might be able to get a 350 pan to work but you would have to bash the sides out a bit for the clearance or just get a 400 pan
Old Feb 21, 2002 | 02:40 PM
Stroked-Z's Avatar
On my oilpan....just a generic chrome type stock replacement pan (am changin it anyhow) i did not have to bash out the sides. It bolted in with no mods.
Old Feb 22, 2002 | 01:02 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The bolt pattern for the pan is the same on the 400/350. But like TempesT68 was saying there is sometimes more clearance needed for the longer stroke of the 400 crank. When using a standard 350 pan it can cause problems with the crank making slight contact. You would have to see the two pans side by side to tell the difference.
I used a 350 pan on a 400 buildup when i tore it down to freshen the motor you could see were the crank was hittiing the 350 pan. I couldnt hear it because of the loud exhaust. Couple taps with a hammer fixed that.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
