Weld repair cracked block?
Old Feb 23, 2002 | 07:01 PM
G92Joe's Avatar
I have a '87 small block with a 2" long crack in the lifter valley going into the water passage, near #8 cylinder, about 2.5" down, parallel from the deck. Is this repairable using an epoxy like Devcon, or should it be replaced? Thanks ...........
Old Feb 23, 2002 | 07:11 PM
1982chevycamaroz28's Avatar
needs to be replaced. if u try to fix it even with welding it would just get worse later on or right after ur done welding it. so the thing is to that it has to be replaced.
Old Feb 23, 2002 | 07:12 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Paul Harvey would tell you to go and get some JB Weld. He said someone used it to repair a back hoe's cracked engine block.
:hail:IROC-Z
Guest
Guest
Posts: n/a
I wouldnt even attempt it. Soon as you fire the car up, the head is going to try to lift off the block, and that area is what prevents it from going anywhere. The question really isnt is it going to crack again, but when.
You should be able to pick up a decent replacement block for a couple hundred bucks at most.
Old Feb 23, 2002 | 07:30 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
You could try to repair it but welding cast iron is a ***** im sure you can find a replacement block for cheap.
Old Feb 23, 2002 | 08:10 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
throw it in tha' gutter and go buy another.
Buy a bottle of antifreeze next time.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
C409
Jan 21, 2016 08:29 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
