Lets play the HP game!!
Old Feb 24, 2002 | 11:55 AM
MR. JORDAN's Avatar
Start with a stock 87 LG4. (roughly 165hp)
Add a XE256H Cam.
Port the heads and add headders.
Add 3" plumbing from Y pipe to an 80 series Flowmaster.(no cat).
All Emissions delete.
Open element on top of a Q-Jet with better hangars.
Add a 1" carb spacer.
And lastly an MSD ignition.
How much HP is the LG4 pushing?
Old Feb 24, 2002 | 12:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Since no one has replied I'll take a guess, around 225 hp.
Old Feb 24, 2002 | 06:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
sounds about right
mid 220s give or take
Old Feb 24, 2002 | 06:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ditch the open element and put something correct on there, such as a stock L69 setup, about 5 more HP.
You're going to have a tough time deleting "all emissions" with the stock computer controls. You can lose some of them, such as the AIR; but the various sensors and the computer-controlled carb and distributor will have to stay. With no AIR and a straight pipe as opposed to leaving the AIR on and using a good high-flow cat, you might gain 3 or 4 HP at most. It costs very little power.
ZZ3Astro
Aug 13, 2019 12:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
