will it run pretty good????
Old Feb 25, 2002 | 08:49 AM
82sportcoupe's Avatar
well, i have everything i need to get started on my engine. any suggestions would be nice cuz i havent put it together yet and i can still exchange parts if i need to.
gm 350 lm1 (factory bore and never been fired up)
World sportsman 2 heads
comp cams xe262h
performer eps intake
qjet carb (rochester)
9.3:1 compression with 64cc heads
1.6 ratio rocker arms
k&n filter
hedman headers, and ypipe
stock ignition
3.42 gears
700r4 tranny
any very rough estimates on hp and trq at the crank?? any suggestions on what you would do differently? I would go with a higher duration cam but i dont think im going to change the trq converter. Unless it would be stupid not to do it.
thanks,
the person that was banned for no reason (hehe!)
Old Feb 25, 2002 | 10:44 AM
lets put it this way, do you think that there is a slight possiblility that i will break 13.9 in the quarter (uncorrected)? the track will be in NE ohio.
Old Feb 25, 2002 | 02:22 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Well, I have basically the same setup, but different
I have the Comp magnum 270, holly 750 mech sec, Performer RPM intake, and cheapo header, with a TH350. Put my truck in the high 13's. 3.73's, 4400 lb.
Work it out from there.
Cheers
Richard
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
jackhammer
Aug 15, 2015 10:04 PM
Omega
Exterior Parts for Sale
Aug 10, 2015 10:19 PM
