heads for a 305
Old Feb 25, 2002 | 11:36 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
heads for a 305
any that are good and improve the really bad valve angle???
lemme know which ones are superior......................
Old Feb 25, 2002 | 03:17 PM
GreenProStreet's Avatar
It is hard to find heads that have the small 1.94 intake valve. Most step up to a 2.02 valve, whick will that claer the bore of the 305. World S/R Torquer are the only alluminum heads that will, bt they were designed as a replavemnet iron head, cast in alluminum, so minimal flow difference. The alluminum vs. iron, will give only a 2-3% power increase. Not worth the swap.
Just swap over to a 350!
Old Feb 25, 2002 | 04:37 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
afr makes em in aluminum http://www.airflowresearch.com/
where i plan on getting mine........they put edelbrock and trick flow to shame on flow rates
Old Feb 25, 2002 | 04:51 PM
E-Z Rollin's Avatar
If youb don't want to spend alot of money,get a set of L98 vette alum. heads and pocket port them. They have 58cc chambers 1.94 ints. 1.50 exh. and will clear the 305 bore, use a 350 head gasket with the smallest bore you can find,Ferrera makes one thats 4.060.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
