oil ?????
Old Feb 25, 2002 | 09:08 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
oil ?????
hey all
in the Z28 i just bought, i went to check the oil, and the first time i pulled the dipstick out, it said add a quart
then i put the dipstick back in, pulled it out and it said it was full
and yes i cleaned it off between checks
Old Feb 25, 2002 | 09:15 PM
camaro6spd's Avatar
maybe on the firt time the dip stick was not all the way in....mine does this some times, jiggel it and puch sometime it does not go all the way down.
Old Feb 26, 2002 | 05:21 AM
yeah i tried this
sometimes it would come out reading enough
and sometimes it would say not enough
Old Feb 26, 2002 | 08:25 AM
Vader's Avatar
RS,
Check the oil level cold, before the engine has been run at all. If you have any drainback problems, you may get varying readings. You should also make certain the dipstick is straight, and the "cup" that covers the dipstick tube in the block is fully seated.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
