Posi Traction Question
Old Feb 25, 2002 | 10:11 PM
iroc_cragg's Avatar
HEY
I HEARD THAT U COULD ONLY GET THE POSI TRACTION IF U HAVE 4 WHEEL DISCS. I HAVE 4 WHEEL DISCS AND A 3.42 REAR AXLE. I LOOKED FOR THE POSI TRACTION CODE AND I DO NOT HAVE IT. DID GM NOT PUT THE CODE ON OR WHAT
http://camaroz28.cardomain.com/id/56424
Old Feb 25, 2002 | 10:34 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I have drum brakes in the back and have POSI traction. I don't think it was just for 4 disc brake set-ups. If it is then I must have one rare car
Old Feb 26, 2002 | 01:07 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, that's definitley not true about the 4 wheel disk brakes and posi. I've got drums and a posi.
About the RPO codes, I'm not sure if they have one for a posi. I do know they have one for the gear ratio though. I'm pretty sure that all Irocs originally came equipped with a posi. If you're not sure, you can check it pretty easy. Its a good idea anyway, in case someone has swapped out the rear, or the posi is blown. Anyway, jack up the rear of the car, and spin the drivers wheel foreward. If the passenger wheel spins backwards you don't have a posi. If it spins foreward then you do.
Old Feb 26, 2002 | 02:00 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
G80 = limited slip differential. The RPO code exists and should be present on the Service Parts Information label if the car had a 'posi' from the factory. LSDs were not limited to 4 wheel disc cars only...
Laterzzzzzzzzzzzz,
Matt
Old Feb 26, 2002 | 02:05 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Also, look for the limited slip additive metal tag attached to the diff cover by one of the bolts.
Cheers
Richard
Old Feb 26, 2002 | 03:33 PM
GreenProStreet's Avatar
I feel your pain ... Well I dont, personally, because my SC has drums and posi, so your source is wrong.
Dont let peg-leggin' stop you from doing those burnouts! :rockon:
Old Feb 26, 2002 | 06:17 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
not all irocs were equipped with limited slip until 1990. as i recall, only the aluminum drum version wasn't available with it and the only one standard with it was the 5.7 car's. not having the g80 code though, you likely just plain don't have it unless someone put it in.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mcgarnicle
Aug 12, 2015 04:58 PM
