Complet Tune Up?
Old Feb 28, 2002 | 06:06 AM
RS91's Avatar
Complet Tune Up?
My Car has about 110,000 miles on it and Can't remember when was the last tune up. I want to do it my self but need to know what I need to do and list of parts need to be changed....
NOte: I already got the MSD rotor, cap, wires and coil but I know I need a few more things...
Thanks....
Old Feb 28, 2002 | 06:11 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
New plugs and new O2 sensor if you use it.
Change oil and all filters. Check/adjust timing.
Old Feb 28, 2002 | 10:10 PM
Vader's Avatar
A basic tune-up MUST include:
1. Cooling system inspection;
2. Clean or replace spark plugs;
3. Ignition wire testing;
4. Distributor cap/rotor (if you don't have the OptiSpark);
5. PCV valve cleaning or replacement;
6. Air filter;
7. Cleaning the IAC;
8. Checking/setting TPS voltage;
9. Check/adjust minimum air rate;
10. Check/adjust timing;
11. Code scan;
Don't mistake this for a complete car service. That should include all required maintenance for a vehicle with a given age and mileage. The general overview is something like this:
That should be a good start.
Old Mar 1, 2002 | 07:11 AM
RS91's Avatar
Thanks guys.... I will try to do all your suggestion ....
again thanks....
Old Mar 24, 2002 | 03:42 PM
RS91's Avatar
I Just replaced my O2, Map, coolant temperator Sensor and EGR valve. Now my car runs alot stronger and some how my Hooker cat back sound alot better.
Thanks....
MantyZ28
Nov 8, 2015 06:54 PM
dbrochard
Sep 19, 2015 08:13 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
