Need Electric waterpump recommendations.
Old Feb 28, 2002 | 11:24 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am considering getting an electric waterpump.
What are some things to look for when comparing models.
Will I get a good HP increase running one?
Also, I ordered a CSI digital temp gauge that can turn on and off my electric fans as well as control an electric waterpump. Is it safe to have the waterpump turn on and off or is it better to just have it on all the time?
thanks
Old Feb 28, 2002 | 12:33 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
don't do it
mechanical are much more effective and reliable. I know someone that had a brand new moroso fail because the setsecrew on the impeller came off. twice
Not worth the small hp you will save.
Old Feb 28, 2002 | 12:48 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I agree.I wouldn't run an electric water pump on a street driven car, unless it's only driven occasionally, like weekends.They're just not reliable enough for a daily driver yet.
-Rich-
Old Feb 28, 2002 | 08:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A good aluminum mechanical pump is more what you need. Electric motors fail and having a water pump fail on the street isn't a good thing to happen.
Electric water pumps are really designed for drag racing only. It allows us to turn the pump on when in the pits and have the coolent circulating to aid in cool down.
The belt drag on a mechanical pump is only an extra 2-3 hp so for street use there's not a big improvement in performance.
Old Mar 1, 2002 | 02:02 AM
Zepher's Avatar
Ok, I thought I read somewhere that there was up to a 15hp increase when using an electric pump.
If it's only 2-3hp, then I'll probably go with a nice mech. unit.
Thanks Guys
Old Mar 1, 2002 | 06:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My recommendation: don't do it.
Get a Stewart www.stewartcomponents.com instead
Old Mar 1, 2002 | 06:55 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
In LT1s I hear that it's a worthwhile thing to do to run an electric pump but in thirdgens it is (just in case this hasn't been driven home enough) not worth it.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
