Ongoing overheating help make it stop..
Old Mar 1, 2002 | 10:22 AM
David Petersen's Avatar
I'm at the end of my rope here but I know with your help I can figure this out!!! Please post ideas on what I should check and what to look for. My 89 RS keeps on overheating I have had it in the shop several times with no luck!!!!! Here is what I know... the car will not overheat if it just sits and idles even for over an hour. But if I drive her more than 8 blocks she is boiling over!!! The fans are working as they should, I drainded and refilled the radiator (didn't flush or back flush it) but the raiditor is fairly new. It's thingking maybe the exta RPM's from driving are doing somthing,beacsue if I really get on it you can almost watch the temp rise. Cracked head?? Maybe head gasket??? Here is what I am running.. 88' 350, T-5, auto radiator w/oil cooler,MSD 6AL,K&N filters other than that bone stock, 98K on the engine.
Old Mar 1, 2002 | 10:31 AM
87-ZMAN's Avatar
check for any leaks? check your oil to see if it has a milky color-if it does then probably head gasket or cracked head. also check radiator hoses and see if they need replacement. hope this helps
Old Mar 1, 2002 | 10:35 AM
sleeper's Avatar
Check this post...
https://www.thirdgen.org/techbb2/sho...threadid=88049
Old Mar 1, 2002 | 10:37 AM
Ok I checked the oil but teh car has been at the body shop for a while so I will check it again. Also brand new hoses all around, new water pump and new 180* thermostat.
Old Mar 1, 2002 | 10:46 AM
Woha thanx Sleeper and Vader!!! I don't remember any spring coil being in the lower raidiator hose in the old one I took off or with the Good year hose set I put on I will check there first.
Old Mar 1, 2002 | 11:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at that, also make sure the lower air dam is intact. It's a black piece of plastic about 6" tall that goes most of the way across the car, immediately below the radiator.
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
86White_T/A305
Aug 17, 2015 12:16 AM
z28addict8490
Aug 7, 2015 08:48 PM
