Ford injector people enter!!!!!!!
Old Mar 1, 2002 | 11:34 AM
88greyiroc's Avatar
i bought 19lb injectors they are meade by ford i am gonna put them into my 350 tpi will i have any problems?i am looking for people who have already done this i wanna know if they will work good if i just put them in with no tampering????
Old Mar 1, 2002 | 02:59 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I put 24# SVO injectors in my 383 and haven't had any problems yet, but it's only run for about an hour.
Old Mar 1, 2002 | 03:32 PM
Guest
Guest
Posts: n/a
Just make sure the o-rings are the same size as whats in your car now. Some of the Ford injectors have smaller o-rings, and you dont want those.
Old Mar 1, 2002 | 05:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They will probably be too small and the car will run lean, although you might maybe be able to compenstae enough with fuel pressure.
I put a set of them in my wife's 4.9 Caddy, they work perfect there (no codes, excellent gas mileage), so they would also be about right for a 305 I would think but not enough for a 350 without at least some reprogramming.
Old Mar 1, 2002 | 06:09 PM
88greyiroc's Avatar
i posted this so people who have done this could tell me the flow rate between ford and chev is different the 19lbs in a chev iroc z are suppose to flow 22lbs because of a strong fuel pump or something.i wanna know if thats enough.
Old Mar 1, 2002 | 10:29 PM
88TAJeff's Avatar
Car: 88 T/A
88, I think you'll be fine with those injectors, I saw there's a couple of people here running 19 lb injectors on their 350's without any trouble. Apparently, they're good up to 300hp.
I've been thinking about buying those same injectors from the same guy, and I'm curious, are they in good condition?
Why don't you just put them in since you have them, and we'll both know how they work, and it will save the anticipation for both of us.
Thanks.
Old Mar 1, 2002 | 11:28 PM
Guest
Guest
Posts: n/a
The difference in pressure (37psi to 44psi) makes the 19# injectors 20.7# instead. If you were to run 49.5psi (which would be ok) those injectors would flow 22#'s, just like whats in there now.
Old Mar 2, 2002 | 07:50 AM
88greyiroc's Avatar
the injectors themselves are in excellent shape and they were shipped perfectly etc. someone told me that its good to run a bit lean but not too much because i don't have a fuel pressure regulator so i can't bump up my fuel pressure.
Old Mar 2, 2002 | 11:51 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I had the 24's in my GTA and ran awsome, and im putting the 19's in my vert next week when I get em... Theyre A-OK by me, even though theyre Furd!
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
BAMiller
Sep 14, 2015 06:38 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
