Afpr?
Old Mar 1, 2002 | 09:13 PM
Casey'91Z28's Avatar
Afpr?
I just installed a Holley AFPR and I set it to 46 PSI(stock was at 42 PSI). I drove it around and felt like it pulls a little harder so I was happy. But when I went to drive it later it had a hard time starting. I hope this isn't a sign of my fuel pump going out. Should I just lower the pressure?
Old Mar 2, 2002 | 07:28 PM
ttt
Old Mar 2, 2002 | 07:42 PM
rezinn's Avatar
Describe "hard time starting." Yes, raising your fuel pressure can strain the pump. But if it is, you know that the pump is old anyhow, so you either change it and keep the pressure high, or lower it and wait for it to die right before you need to go to work/school/anything one day and leave you stranded.
Old Mar 2, 2002 | 07:49 PM
rezinn,
The hard time starting is that it will crank for a little and it will finally start and then it almost dies again but I give it a little gas and it runs fine.
Old Mar 2, 2002 | 08:11 PM
rezinn's Avatar
How does the fuel pressure hold after the car is turned off, after you turn the key to prime the pump? How old is the fuel filter?
There are many things that could cause hard starting, the AFPR itself could be one culprit. Did you get a new diaphram? If it is ruptured, that may cause hard starting. As could a bad fuel pump relay, bad wiring, leaking injectors, pump itself... You may want to attempt replacing the afpr with the stock piece and seeing if anything improves.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
