estimate the difference
tommorow my car 350tpi camaro is getting new 19lb ford fuel injectors, new o2 sensor.the old fuel injectors some of them were stuck open when i bought the car so i don't know how bad it affects there performance, and i am also gettin the cat gutted.do you think i will notice a difference?
If you had bad injectors, then new ones should give you easier starting and better gas mileage, maybe a little more power. If the injector wiring is defective, that could cause the injectors to ground and dump fuel. This will still happen if the problem was not the injectors themselves. Probably nothing you'll be able to feel, except the mental sotp difference that comes with every mod.
Transmission: 4L80E/4L80E
Uh, 22, actually.
19's can work with a mild 350 better than 22's. Up the fuel pressure to compensate for the lower flow area, the pressure drop will vaporize the gas even better.
Car: 88 T/A
88, Finally getting this injector thing done. Excellent. Let us know how they turn out, I'm curious. Those injectors you got are almost 1/2 price of new ones.
Thanks,
Jeff
Thanks,
Jeff
Ok, z28, that was already said, and if you are talking about my post I didnt mention the stock size. I said that a 19# ford injector would equal approximately a 21 in a gm vehicle because the fords are rated at a lower fuel pressure so when you run the higer fuel pressure that gm used it runs about 21 like I said.
Ben
Ben
hey guys,
sorry i didn't get back to you guys sooner i have been busy working.Anyways they are in my car has a lot better throttle response now.And it does not smell like a skidoo. The problem i have now is the car after its warmed up will idle really low then back up to normal idle then down low then back up and it keeps doin it.Do you guys have any idea what it could be?
Numbah-1
Sep 12, 2015 08:57 PM
