5.7 tpi runs then dies lots of extra fuel
Old Mar 5, 2002 | 09:05 PM
AK TA's Avatar
my car will start if i give it gas and then runs a little while still
giving gas and dies, fuel pressure has been checked and
it keeps up a constant 37-40 psi ecm has been changed
o2 has been changed same with MAF there were no codes show
ing anyway and still aren't there is spark, when it does run
alot of fuel comes out pipes leaves long black trails
please email any suggestions slc99701@yahoo.com
Old Mar 5, 2002 | 10:45 PM
rezinn's Avatar
Any work done to the car recently? How is your timing set? How is the ignition? Does your ses light ever come on?(does it work?) more info please.
Old Mar 7, 2002 | 05:46 PM
AK TA's Avatar
only work that was done to the car before it first started
acting up were the routine oil change, and maybe a cleaning of
the k and n air filter, oh and the battery went out so it got
a new one of those also. before the car finally broke down some
times when i would push on the gas pedal it would hesitate a
second or so before reacting, other then that it ran fairly well
for me. It does have an auto start that does locks and trunk as well and that did go out before the car broke down, it slowly worked sometimes then not at all, i went over the wireing under
the dash and couldnt find anything that looked obvious while
i checked all the fuses, the wireing is now intact but the
unit has been unplugged and removed, after the car would
no longer stay running, i've changed the cap rotor spark plugs
spark plug wires the electronic control module, the 02 sensor
i've tried a new mass air flow sensor on it but it ran the same
so i took it back , the timeing i don't know much about but
have someone helping with that who has done a tune up for me
before and set it before, i've looked over the obvious showing
parts of the wireing harness and havent found anything but one
plug that appears a little burnt its grey with a red wire and
its located behind and to the left of the coil i've scanned for
error messages and i only get the code it gives to let you
know the system is working.
Old Mar 7, 2002 | 07:41 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Did you check the map sensor?
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
